Starting at the source. Custom Low-noise fan
Smart temperature control. Real-time adaptation
Silence in your hands. Industry’s first ultra silent mode
Cell-level Protection
Electrical Protection
Structural Protection
Monitoring-level Protection
System-level Protection
Emergency Protection
Safety is engineered into the system from the battery cell to the internal protection design. With multiple fire-safety mechanisms working together, it helps reduce risks and keeps energy storage safe and reliable.
Designed for fast installation. Battery modules stack easily with a plug-and-play structure. Quick-connect terminals on the grid and backup sides eliminate complex wiring, while the clip-on CT requires no cable cutting. With no external STS needed, installation is simpler and faster—completed in about 10 minutes.
Easily expand or upgrade your system. Mix batteries of different capacities, old or new.
GW5K-ETA-G20
700 ~ 950
6.7 / 7.4
21 / 21 / 21
Max. Apparent Power to Grid (kVA)
5
5
GW6K-ETA-G20
700 ~ 950
8.1 / 8.9
21 / 21 / 21
6
6
GW8K-ETA-G20
700 ~ 950
10.7 / 11.8
21 / 21 / 21
8
8
GW9.999K-ETA-G20
700 ~ 950
13.4 / 14.7
21 / 21 / 21 / 21
9.999
10
GW10K-ETA-G20
700 ~ 950
13.4 / 14.7
21 / 21 / 21 / 21
10
10
GW12K-ETA-G20
700 ~ 950
16.1 / 17.7
21 / 21 / 21 / 21
12
12
GW15K-ETA-G20
700 ~ 950
20.1 / 22.1
21 / 21 / 21 / 21
15
15
GW20K-ETA-G20
700 ~ 950
26.7 / 29.4
21 / 21 / 21 / 21
20
20
GW25K-ETA-G20
700 ~ 950
33.3 / 36.7
21 / 21 / 42 / 42
25
25
GW29.999K-ETA-G20
700 ~ 950
40.0 / 44.1
21 / 21 / 42 / 42
29.999
GW30K-ETA-G20
700 ~ 950
40.0 / 44.1
21 / 21 / 42 / 42
