MENA
IP55
LiFePO4
GoodWe's BAT Series high-voltage lithium batteries, available in 102.4kWh and 112.6kWh capacities, are specifically designed for small to medium-sized commercial and industrial (C&I) applications.
Paired with GoodWe ET hybrid inverters, Static Transfer Switch (STS) box, the BAT battery system provides a complete, easy-to-install, and high-performance energy storage solution. This powerful system delivers efficient energy backup, peak shaving, and optimized load management.
Max. Continuous 0.9C charging & 1.1C discharging
Support 4 units in parallel, scaling up to 450kWh
Pack-level humidity monitoring and automatic dehumidification
Aerosol-based fire suppression system at pack- and cabinet-level
IP55
LiFePO4
The BAT battery is built on reliable LFP technology, offering high cycle stability for long-lasting performance. Safety is enhanced through pack-level humidity monitoring with automatic dehumidification, ensuring optimal internal conditions. In addition, an aerosol-based fire suppression system provides fast-acting protection at both the pack and cabinet levels, delivering multi-layered safety across the entire system.
Designed for dynamic energy needs, the BAT battery supports continuous charging at up to 0.9C and discharging at 1.1C, enabling fast energy response. With support for up to 4 units in parallel, the system scales effortlessly to 450kWh, making it ideal for a wide range of commercial and industrial applications.
GW102.4-BAT-AC-G10
Usable Energy (kWh)
100
Nominal Voltage (V)
512.0
Max. Charge / Disharge Current (A)
180 / 220
Fire Safety Equipment
Aerosol (Pack & Cabinet Level)
Ingress Protection Rating
IP55
GW112.6-BAT-AC-G10
Usable Energy (kWh)
110
Nominal Voltage (V)
563.2
180 / 220
IP55
