DNS G4 Series
3-6 kW | Single Phase | 2 MPPTs
< 25dB
20A
As the fourth generation of GoodWe’s proven single-phase, dual-MPPT residential inverter, the DNS G4 series delivers enhanced performance, reliability, functionality, and safety—offering homeowners a more powerful and versatile solution for solar needs.
20A per string & 200% PV oversizing
AI-driven AFCI 3.0 for safety
Easy installation, 31% lighter
Easy paralleling via GoodWe smart dongle Ezlink3000
< 25dB
20A
Superb Safety & Reliability
GoodWe's DNS G4 Series features a built-in rapid shutdown transmitter, enhancing system integration and safety. With optional AI-driven Arc Fault Circuit Interrupter (AFCI), the inverter is able to detect arc fault failure, sending alarms through monitoring systems and breaking the circuit simultaneously.
Built-in rapid shutdown transmitter
Type II SPD on both AC and DC sides
The DNS G4 series inverter supports mixed parallel connection with GoodWe MS G4 inverters when paired with the GoodWe smart dongle EzLink3000. This enables flexible and efficient system expansion while reducing investment costs.
Flexible paralleling with GoodWe MS G4 inverter
GW3K-DNS-G40
Max. Input Voltage (V):
20
Weight (kg) :
9.2
Nominal Output Voltage (V) :
220 / 230 / 240, L / N / PE
GW3.6K-DNS-G40
20
Weight (kg) :
9.2
GW4.2K-DNS-G40
20
Weight (kg) :
9.2
GW5K-DNS-G40
20
Weight (kg) :
9.2
GW6K-DNS-G40
20
Weight (kg) :
9.2
