3-6kW │ Single Phase | 2 MPPTs | Hybrid inverter (LV)
Elegant & compact
The GoodWe ES G2 inverter, ranging from 3 to 6kW, is a single-phase hybrid inverter designed to increase self-consumption of the generated solar energy, with the ability to control the flow of energy intelligently. The inverter can automatically realize UPS-level switching to the back-up mode in less than 10ms, with strong backup ability to withstand heavy loads like air conditioners. Its smart design also offers great flexibility for demanding scenarios as it supports parallel connection for dependable backup power supply. Featured with plug-and-play, compact design, and minimal weight, PV installations are quicker and easier to complete than ever before. Importantly, ES G2 is compatible with a wide range of low voltage batteries such as GoodWe Lynx Home U battery. For homeowners looking to achieve a high degree of energy autonomy, reliable power supply and affordable energy prices, the ES G2 is the right choice.
Smart load control with dry contacts
Optional AFCI on DC side
Remote Shutdown
Elegant & compact
ES G2 Series allows for quick-connect Plug & Play on both AC and DC terminals that massively reduces the installation time , which makes it particularly efficient and easy to install. Its elegant and compact design makes it a perfect house fit-in choice for private homes.
Elegant and compact design
The power supply ability in backup mode supports large loads for critical operations. To use even more self-generated solar energy in your home, its maximum DC input current of 16A and compatibility with high-power modules generates more power and reduces the amount of electricity purchased from the grid to adapt to your needs.
Strong backup power supply
Maximum 16 A DC input current per string
High-power module compatibility
GW5000M-ES-20
40~60
60/60
GW5000-ES-20
40~60
120/120
GW6000M-ES-20
40~60
60/60
6000
6000
GW6000-ES-20
40~60
120/120
6000
6000
GW3600M-ES-20
40~60
60/60
3680
3680
GW3500L-ES-BR20
40~60
75/75
3500
3500
GW3000-ES-20
40~60
60/60
3000
3000
GW3600-ES-20
40~60
75/75
3680
3680
