ES LD Series
5-10kW | Split & Two Phase | 2 MPPTs | Hybrid Inverter
Micro-grid
IP66
The GoodWe ES LD Series (5–10 kW) is a split & two phase hybrid inverter designed for residential and small commercial applications. It offers flexible compatibility with both on-grid and off-grid systems, supporting 48 V low-voltage lithium or lead-acid batteries with battery-ready functionality. The ES LD Series delivers AC output voltages of 120/208, 127/220 V, 120/240 V, and 127/254 V to meet diverse market requirements.
200% DC oversizing & 200% AC overload
3-in-1 Port: Generator & On-grid Inverter & Smart Load
Seamless switching < 4ms
AI-driven AFCI 3.0 for safety
Micro-grid
IP66
Reliable Backup Power, Always Ready
With seamless switching in under 4ms and full compatibility with generators—including battery charging support—the ES LD ensures your essential loads stay powered without interruption, even during outages.
Generator compatibility and charge for battery
High Performance and Adaptable Applications
With 20A per string, 200% PV oversizing, and 220A continuous charge/discharge, the ES LD ensures high-performance solar integration while offering adaptable operation—supporting on/off-grid parallel setups and two & split phase output options available to meet diverse household needs.
Supports on-and off-grid parallel operation
Two-phase and split-phase output options available
GW10K-ES-LD-G10
40 ~ 60
220 / 220
40 / 40
10000
10000
GW7.5K-ES-LD-G10
40 ~ 60
165 / 165
40 / 20
7500
7500
GW5K-ES-LD-G10
40 ~ 60
120 / 120
20 / 20
