ESA Series
3-10kW/5-48kWh | Single Phase | All-in-One (HV)
20A
IP66
*Initial stock may be supplied in a gloss white finish.
The GoodWe ESA Series is a fully integrated all-in-one solar and storage solution that combines inverter and battery in a pre-wired, modular design—making installation significantly faster and easier. Engineered for flexibility, the ESA system allows seamless expansion to meet evolving energy needs, with scalable battery capacity for future upgrades. With its streamlined setup, the ESA Series can reduce installation time by up to 50%, making it an ideal choice for efficient and adaptable residential energy systems. It also supports dynamic tariff optimization with AI-driven EMS.
1C charge/discharge for rapid energy cycling
Fanless design for quiet operation, noise <30dB
Dual output ports for simplified installation & off-grid capability
Heating mode ensures reliable performance even in -20℃
20A
IP66
Optimized Performance
The ESA energy storage system is engineered for high efficiency and fast energy response, featuring a 1C charge/discharge rate that enables rapid energy cycling. With support for 20A input per string and up to 200% PV oversizing, it maximizes solar energy utilization even under varying conditions.
20A per string & 200% PV oversizing
The ESA energy storage system is designed to adapt to evolving energy needs with maximum flexibility. It supports mixing of old and new batteries, allowing easy system expansion. Each stack accommodates up to 6 battery modules, scalable to 48 kWh, providing tailored storage capacity for different scenarios. With 63A full backup output, ESA ensures reliable power supply for entire residential or small-scale C&l loads during outages.
Flexible battery mixing with different capacity or old&new batteries
Support full backup load with 63A output
GW3K-EHA-G20
350 ~ 550
11.9 / 8.7
20
Max. Apparent Power to Grid (VA)
3000
3000
GW3.6K-EHA-G20
350 ~ 550
14.3 / 10.5
20
3600
3600
GW5K-EHA-G20
350 ~ 550
19.8 / 14.5
20
GW6K-EHA-G20
350 ~ 550
23.7 / 17.4
20
6000
6000
GW8K-EHA-G20
350 ~ 550
31.6 / 23.2
20
8000
8000
GW10K-EHA-G20
350 ~ 550
35.6 / 29
20
10000
10000
GW9.999K-EHA-G20
350 ~ 550
35.6 / 29
20
9999
9999
