Peak Shaving
16A
The ET G2 Series is the latest iteration of the ET Series and has been specially designed to accommodate households' increasing demand for electricity consumption while delivering additional benefits that cater to flexible residential needs.
This inverter features an elegant and sleek design that can harmonize beautifully with the house's aesthetic. With the addition of 12kW and 15kW higher power capacities, the ET G2 is now equipped to deliver even more powerful generation, allowing for optimal energy harvesting. It supports parallel connections with up to 4 units, ideal for expanding energy needs
Integrated dry contact for external loads
AI-driven AFCI 3.0
Up to 160% PV input oversizing
Fast load response
Peak Shaving
16A
Type II surge protection on both DC and AC sides is integrated to protect the inverter from lightning, providing upgraded safety and reliability for the PV system. With integrated Arc Fault Circuit Interrupter (AFCI), the inverter is able to detect arc fault failure, sending alarms through monitoring systems and breaking the circuit simultaneously.
Type II SPD on DC & AC sides
AI-driven AFCI 3.0
The ET G2 Series has been improved for compatibility with high-power modules, with a maximum of 16A input current per string. The 200% PV input oversizing and 98.2% maximum efficiency, drive your inverter to its full capacity to increase your power output in lower solar radiation conditions.
160%
16A
Max. 16A DC input current per string
98.2%
98.2% max. efficiency
GW6000-ET-20
150 ~ 720
Max. Continuous Charging Current (A)
Max. Continuous Discharging Current (A)
6000
GW8000-ET-20
150 ~ 720
8000
GW10K-ET-20
150 ~ 720
40
40
10000
GW12K-ET-20
150 ~ 720
40
40
12000
GW15K-ET-20
150 ~ 720
40
40
15000
