ET LV Series
5-20kW | Three phase | Up to 4 MPPTs | Hybrid inverter
20A
IP66
The GoodWe ET LV Series inverter (5–20kW) is ideal for residential PV systems, offering seamless integration with low-voltage (48V) batteries. Designed for flexibility, it supports a wide range of battery capacities and brands, including GoodWe’s own Lynx A G3, Lynx U G3, and BAT 14kWh low-voltage batteries -making it a versatile choice for homeowners seeking reliable energy storage solutions.
Up to 2x PV input capacity
Seamless switching < 4ms
AI-driven AFCI 3.0 for safety
Unbalanced output up to 150%
20A
IP66
Reliable Backup Power, Always Ready
With seamless switching in under 4ms and full compatibility with generators—including battery charging support—the ET LV ensures your essential loads stay powered without interruption, even during outages.
Generator compatibility and charge for battery
High Performance for Demanding Energy Needs
With a 20A input current per string and support for up to 2x PV input capacity, the ET LV is built to handle high-power solar arrays. Its dual independent battery inputs with a total of 416A enable greater energy throughput and system flexibility—making it the ideal choice for homes with high energy demands and scalable storage setups.
Dual independent battery inputs with 416A
GW20K-ET-L-G10
40 ~ 60
Max. Continuous Charging Current (A)
208 / 208
Max. Continuous Discharging Current (A)
208 / 208
Max. Apparent Power to Utility Grid (VA)
22000
Max. MPPT Current (A)
20 / 20 / 20 / 20
GW15K-ET-L-G10
40 ~ 60
165 / 165
165 / 165
16500
20 / 20 / 20 / 20
GW12K-ET-L-G10
40 ~ 60
250
250
13200
20 / 20 / 20
GW10K-ET-L-G10
40 ~ 60
220
220
11000
20 / 20 / 20
GW8K-ET-L-G10
40 ~ 60
175
175
8800
20 / 20
GW6K-ET-L-G10
40 ~ 60
135
135
6600
20 / 20
GW5K-ET-L-G10
40 ~ 60
125
125
5500
20 / 20
