Fanless & Quiet
16A
ET PLUS+ Series integrates the technical strengths that make it one of the most adaptive options in the market for flexible residential needs. The series brings values of high power generation and charging power for optimal energy harvest, flexible applications enabled by smart load control and 100% unbalanced output, and sustainable system reliability and safety. It also presents peak shaving that balances power demand and grid power imported, to effectively reduce extra grid demand. Furthermore, thanks to dry contact in the inverter, external loads such as heat pumps can also be flexibly activated to optimize energy consumption. It is a truly versatile quality investment piece that extends application scenarios and maximizes self-consumption ratios.
Smart load control
<10ms UPS-level switching
In-built Type II SPD on DC side
IP66 ingress protection
Fanless & Quiet
16A
Take smart load control to customize the power generation to accommodate to your load consumption needs. Thanks to the integrated export power limit, ET PLUS+ Series can adapt to any power limit imposed by the local energy provider. Peak shaving is also supported to reduce power consumption during periods of high demand, which would reduce peak demand charges. Enjoy the smart home with smart energy control.
Smart load control
Power export limit
Peak shaving
The ET PLUS+ Series offers a grid-connected version featuring GoodWe Battery Ready option to activate energy storage with one activation code — a simple way to future-proof your home for an energy storage system. Take smart load control to customize the power generation to accommodate to the load consumption needs or prioritize battery charge via PV Master App to adapt to different daily use scenarios. Enjoy the simple and flexible power generation and storage in control.
Battery ready option
Forced battery charging
With 150% DC input oversizing and 98.2% maximum efficiency, the inverter massively increases the daily energy yield under various solar radiation conditions. Its maximum DC input current of 16A and compatibility with high-power modules help generate more power and reduce the amount of electricity purchased from the grid to adapt to your needs.
150%
150% DC oversizing
98.2%
98.2% max. efficiency
Maximum 16A DC input current per string
GW10KN-ET
180~600
25/25
11000
10000
GW10K-ET
180~600
25/25
12.5
11000
10000
GW8KN-ET
180~600
25/25
8800
8000
GW8K-ET
180~600
25/25
12.5
8800
8000
GW6.5KN-ET
180~600
25/25
7150
6500
GW6.5K-ET
180~600
25/25
12.5
7150
6500
GW5KN-ET
180~600
25/25
5500
GW5K-ET
180~600
25/25
12.5
5500
