50/100kW | Three phase | 1/2 MPPT | Hybrid inverter (HV)
100% unbalanced
The GoodWe ETC Series is a versatile three-phase hybrid inverter designed to accommodate a wide battery voltage range, spanning from 200 to 865 V. Its user-friendly Plug & Play modularized design consists of five main modules: MPPT, DC/DC, DC/AC, STS, and EMS. This design approach offers increased flexibility and simplifies the installation process.
Featuring UPS-level switching with an impressive response time of less than 10 ms, the GoodWe ETC Series ensures a seamless and uninterrupted power supply for critical loads. Additionally, it incorporates a Type II SPD for enhanced system safety.
The combination of the ETC hybrid inverters and the GoodWe battery system Lynx C (ranging from 101kWh to 156kWh) creates a highly efficient energy storage solution. This solution is an excellent choice for commercial and industrial applications, whether the goal is to increase self-consumption, implement peak load shaving, or establish a robust backup power system.
Modularized design
<10 ms UPS-level switching
100% unbalanced output
Built-in Type II SPD
100% unbalanced
100% unbalanced output increases load flexibility, extends application scenarios, and maximizes self-consumption ratios. The powerful 110% continuous AC overload capacity guarantees robust energy supply in backup mode.
Powerful backup supply ability
With the ability to make a smart UPS-level switching in less than 10 ms, an uninterruptible power supply is always operational for critical loads. The lightning protection on both AC and DC sides prevents voltage peaks from destroying connected devices and secures system reliability.
UPS-level switching
Built-in Type II SPD (Type I + II offered as optional configuration)
GW50K06-ETC
200~865
100/100
100
55000
Max. Output Apparent Power (Back-up) (VA)
55000
GW100K06-ETC
200~865
100/100
100
110000
110000
GW100K07-ETC
200~865
100/100
100
110000
110000
GW50K07-ETC
200~865
100/100
100
55000
55000
