MENA
BMT-G4/088A | 335W | 355W | BMT-G4/108A | 415W
Ultra-lightweight Solar Panel
Feather-Light, Steel-Tough
No Roof Penetration
Ultra-lightweight
Galaxy Series is a featherlight BIPV (building-integrated photovoltaic) product designed for industrial and commercial applications. With an ultra-lightweight design and frameless surface/edge protection, Galaxy is especially ideal for low load-bearing and poor waterproofing roofs while ensuring power generation efficiency. An additional layer of 1.6mm tempered glass on the surface greatly improves its impact resistance to wind and hail, bringing durability and safety to buildings with all-weather protection. Furthermore, the zero-penetration installation methods of Galaxy, clamping, gluing and railing, protect the roof from water leakage. Every panel can be rapidly installed in three minutes, saving up to 60% of installation cost compared with conventional PV panels.
Ultra-lightweight design 5.6 kg / m2
Wind and Hail impact resistance
No penetration
3 min/pcs rapid installation
High-efficiency PERC/TOPCon Cells
Up to 213W/m2 of Power Generation
No Roof Penetration
Ultra-lightweight
The ultra-lightweight design makes it possible for roofs with a low load-bearing capacity to install PV systems compared with conventional PV modules, catering to more application scenarios.
60% lighter than conventional modules
Versatile applications
Galaxy panels are not only for C&I roofs, but also suit for patio, pergola, shed, carport, as well as solar trailer and wall mounted installation.
C&I roofs
Patio, pergola & shed
Solar trailer
The integrated tempered glass provides better mechanical performance to protect cells from deformation by hail and wind, which helps ensure optimal power generation.
1.6
1.6mm tempered glass integrated
25
Pass the impact test using ice balls within 25mm diameter and a velocity of 23m/s
BMT-G4/108A
Power
415W
Size
2275 x 897 × 4 mm
Unit Weight
5.6±0.4kg/m²
Cell Type
Mono PERC Half Cells (108pcs)
Module Efficiency
20.3%
BMT-G4/088A
Power
355W
Size
2138 x 780 × 5 mm
Unit Weight
5.6±0.4kg/m²
Cell Type
N-Type TOPCon Half Cells (88pcs)
Module Efficiency
21.3%
BMT-G4/088A
Power
335W
Size
2116 x 777 x 5 mm
Unit Weight
5.6±0.4kg/m²
Cell Type
Mono PERC Half Cells (88pcs)
Module Efficiency
20.4%
