Black Start
100% DOD
Featuring enhanced safety and reliable performance, GoodWe's high-voltage battery Lynx C Series has been specially designed for various C&I solar rooftop applications. Lynx C combines with GoodWe hybrid inverter ETC Series and retrofit battery inverter BTC Series to form a highly-flexible energy storage system that helps manage energy use for maximized self-consumption and ensures a reliable power supply for business. In addition, the system allows the user to level out peak demands and ultimately leads to the reduction of electricity bills. The battery comes with automatic detection of extended battery modules, which enables easy configuration and fast commissioning.
Remote monitoring & updates via inverter
Easy to transport
LiFePO4 (LFP) battery cells
Auto-recognition modules
Black Start
100% DOD
Lynx C accommodates smart remote monitoring of the whole energy storage system and remote updates. When the battery is running at a low voltage, it automatically enters the low-power sleep mode, which reduces the standby power consumption and guarantees a longer standby time. Take smart control of your smart energy.
Low-power sleep mode
The integrated black start capability ensures the solar plus storage system can continue to run at a certain level even if the rest of the electricity grid is out of service, resulting in system reliability and safety for various scenarios. Insulation resistance test is supported to prevent electrical shocks, ensuring the safety of personnel and reducing or eliminating downtime. Furthermore, the reliable lithium iron phosphate (LFP) battery cell technology ensures maximum safety and a longer life cycle.
Black start capability
LX C156-10
Usable Energy (kWh)
156.67
Nominal Voltage (V)
652.8
100/100
Installation Location
Ground-Mounted
Enclosure Type
IP21
LX C138-10
Usable Energy (kWh)
138.24
Nominal Voltage (V)
576.0
100/100
Ground-Mounted
Enclosure Type
IP21
LX C120-10
Usable Energy (kWh)
119.81
Nominal Voltage (V)
499.2
100/100
Ground-Mounted
Enclosure Type
IP21
LX C101-10
Usable Energy (kWh)
101.38
Nominal Voltage (V)
422.4
100/100
Ground-Mounted
Enclosure Type
IP21
