Auto recognition
Lynx Home U Series is a low-voltage lithium battery specially designed for residential applications with superior performance. Compatible with GoodWe ES/EM/SBP inverters, Lynx Home U Series comes with GoodWe one-stop-shop solution saving you considerable time and effort. It can be used flexibly for self-consumption and backup applications with a wide capacity range scalable from 5.4 – 32.4 kWh. Each battery pack is a standalone unit with an integrated Battery Management System (BMS), eliminating the need for a Power Control Unit (PCU). The installation and commissioning are easier and faster than ever with a simple Plug and Play wiring and module auto recognition during system setup. Meet this highly efficient solution for storing your solar power and use it whenever needed.
Remote diagnosis & update
IP65 protection for outdoor installation safety
Auto recognition
The stackable self-detecting modules are built for ultra-simplified assembly, and pre-wired communication cables provide Plug & Play wiring to skip the complex internal wiring and commissioning, bringing fast installations for an easy start.
Auto-recognition modules
Plug & Play wiring
Lynx Home U Series is compatible with GoodWe ES/EM/SBP inverters, allowing for a more effortless energy storage solution construction. With its wide capacity range scalable from 5.4 kWh to 32.4 kWh, Lynx Home U Series can be set to adapt to the flexible needs whenever you need.
5.4 – 32.4 kWh wide capacity range
Compatible with single-phase hybrid and retrofit inverters
LX U5.4-20
Usable Energy (kWh)
5.4
Nominal Voltage (V)
51.2
50 / 50
Installation Location
Wall Mounted / Grounded
Enclosure Type
IP65
2*LX U5.4-20
Usable Energy (kWh)
10.8
Nominal Voltage (V)
51.2
100 / 100
Enclosure Type
IP65
3*LX U5.4-20
Usable Energy (kWh)
16.2
Nominal Voltage (V)
51.2
100 / 100
Enclosure Type
IP65
4*LX U5.4-20
Usable Energy (kWh)
21.6
Nominal Voltage (V)
51.2
100 / 100
Enclosure Type
IP65
5*LX U5.4-20
Usable Energy (kWh)
27.0
Nominal Voltage (V)
51.2
100 / 100
Enclosure Type
IP65
6*LX U5.4-20
Usable Energy (kWh)
32.4
Nominal Voltage (V)
51.2
100 / 100
Enclosure Type
IP65
