3.6-6kW │ Single Phase | AC-coupled retrofit inverter (LV)
Elegant & compact
The GoodWe SBP G2 Series is an AC-coupled retrofit solution, which is able to upgrade an existing single-phase or three-phase on-grid PV system into an energy storage system by adding a battery. The inverter is compatible with low-voltage batteries ranging from 40 to 60V and allows surplus electricity to be stored in the battery for later use. The integrated plug-and-play solution, compact design, and minimal weight simplify its installation, operation, and maintenance. Importantly, the inverter can automatically realize UPS-level switching to the back-up mode in less than 10ms, ensuring a stable and reliable power supply. An all-round intelligent system for optimized power usage and maximized return on investment.
<10 ms UPS-level switching
Elegant and compact design
IP65 ingress protection
Remote Shutdown
Elegant & compact
SBP G2 Series can make a smart UPS-level switching to a back-up mode in less than 10 ms, ensuring the critical loads experience no interruption. Supporting a variety of communication protocols, SBP G2 Series makes the integration of smart home systems for users' custom needs possible. Easy, smart, and intuitive.
GoodWe SBP G2 is suitable for both single-phase & three-phase systems, adapting to various architecture conditions of users. As an AC-coupled battery storage retrofit inverter, it can effectively upgrade an existing single-phase or three-phase on-grid PV system into an energy storage system by adding a battery.
AC-coupled battery storage retrofit solution
Suitable for both single-phase & three-phase systems
GW6000-SBP-20
40~60
120/120
220 / 230 / 240
6000
6000
GW5000-SBP-20
40~60
120/120
220 / 230 / 240
GW3600-SBP-20
40~60
75/75
220 / 230 / 240
3680
3680
