SMT G2 Series
35-80kW I Three phase I 4/6 MPPTs
6 MPPTs
98.6%
The SMT G2 Series string inverters (35–80kW) are designed for C&I applications, delivering high energy yields and exceptional power density. The 35–50kW models are tailored for low-voltage (127/220Vac) installations. Across the range, support for high-power PV modules is ensured through multiple MPPTs and up to 21A input current per string, delivering consistently optimized performance. The SMT G2 Series comes in two designs: a compact, ultra-low-noise version for the 35/37.5/60kW models, and a reinforced, high-power-density version for the 50/75/80kW models. For reliability, the series includes Type II surge protection on both DC and AC sides, with optional AFCI for enhanced protection.
Remote data monitoring
Lightweight 42 kg design with <50 dB full-load noise
IP66 protection for outdoor installation safety
6 MPPTs
98.6%
Flexible & Adaptable Solutions
The SMT G2 series offers two distinct ranges to meet diverse project requirements. The 35–60 kW models deliver cost-effective flexibility with a lightweight, low-noise design, making installation simple even in compact or noise-sensitive environments. The 50–80 kW models emphasize high yields and power density, with a 6-MPPT design and support for 182/210 mm high-current modules. From small rooftops to ground-mounted plants, SMT G2 provides the right balance of value and performance.
Compatible with 182/210mm modules
Consistent Efficiency & Reliable Protection
The SMT G2 Series supports up to 200% DC oversizing and achieves a maximum efficiency of 98.8%, ensuring optimal energy generation under varying conditions. With Type II surge protection, IP66-rated durability, and optional functions such as AFCI, PID recovery, and night SVG, it offers robust protection and dependable performance for long-term operation.
200%
98.8%
Max. efficiency
IP66
GW35K-SMT-L-G20
Max. Input Voltage (V):
900
42
4/2
Max. Efficiency :
98.4%
Nominal Output Voltage (V) :
127 / 220, 3L / N / PE or 3L / PE
GW37.5K-SMT-L-G20
900
42
4/2
Max. Efficiency :
98.4%
GW60K-SMT-G20
42
4/2
Max. Efficiency :
98.8%
220 / 380, 230 / 400, 3L / N / PE or 3L / PE
GW50K-SMT-L-G10
900
42
6/2
Max. Efficiency :
98.6%
GW75K-SMT
42
6/2
Max. Efficiency :
98.6%
220 / 380, 3L / N / PE or 3L / PE
GW80K-SMT
42
6/2
Max. Efficiency :
98.6%
220/380, 230/400, 3L/ N/PE or 3L/PE
