200V-950V
Fuse-free
GoodWe SMT 50-60kW Series inverter is ideal for medium and large-scale commercial installations.
Harvest solar energy and generate environmental-friendly power for increased return on investment brought by high yields with your commercial PV system. Its unique fuse-free design makes it exceptionally easy to maintain for operators, saving time and money. The superb safety design provides reliable protections in outdoor installation and guarantees stable usage and generation even in extreme conditions. SMT 50-60kW Series is a pioneering inverter for your business and value.
Remote data monitoring
Multi-protocol compatibility
Type II Surge Protection for both DC and AC
IP65 ingress protection
200V-950V
Fuse-free
200V-950V wide input operating voltage range allows the solar system to start at an early stage, fully utilizing the daytime to maximizing solar powered energy generation. The fuse-free design without consumable parts significantly reduces the operating time and costs.
Fuse-free design
With max. 15A DC input current per string, the SMT 50-60kW Series is compatible with different types of high-power modules, which ensures more solar power absorption making it one of the most productive inverters on the market. Up to 6 MPP trackers guarantee optimal energy production even in shade. The maximum energy yields brings you high return of investment (ROI) for your business.
15
Maximum 15 A DC input current per string
6
Up to 6 MPPTs
150%
150% DC input oversizing
110% AC output overloading
98.8%
98.8% Max. Efficiency
GW60KS-MT
Max. Input Voltage (V):
6/2
Max. Efficiency :
98.6%
Nominal Output Voltage (V) :
230/400, 3L/N/PE or 3L/PE
GW50KS-MT
5/2
Max. Efficiency :
98.6%
