MENA
BMT-S2/032A | 110W
Integrated Solar Roof Tile Solution
Shine Your House
Aestheticly Pleasing
Fire Resistance
The GoodWe Sunshine Series is an integrated solar roof tile solution for pitched rooftops to replace traditional solar panels and framework for a sleek, aesthetically-pleasing result, that also maximises your rooftop space for more solar production. The integrated tempered double-glass structure ensures the safety of the roof structure. Featuring improved roof ventilation and heat dissipation, as well as fast installation, the Sunshine tiles can not only improve solar power generation efficiency, but also help households lower energy costs while reducing their overall carbon footprint.
Durable
Ultra Safe
Aesthetic
Rapid Installation
Fire Resistance
The integrated tempered double-glass structure provides better mechanical performance to protect cells from deformation by fire, wind, and rain, which helps ensure the safety of the roof structure.
Burning block test: 300*300*57mm 30minFlame spread test: 10min <1.82m
Wind resistance test: Passed 50m/s
Rain test: Passed 9.5L/min
Sunshine has been certified as a building material and can be used directly for roofing. It is sturdy and durable, with a lifespan that matches that of the building.
Compliant with mandatory certification standards for building materials
Resulting in same life cycle as buildings
The Sunshine product offers a complete replacement solution for metal tiles. Meanwhile, it's characterized with architecture aesthetic designed appearance. With customized color options, it is barely noticeable after installation. Specifically designed installation structure provides easy installation while offering reliable wind-resistant performance.
Non-penetrative installation
Modular design, easy to replace
BMT-S2/032A (Ebony)
Size
1588 x 490 x 23.5 mm
Power Density
180W/㎡
Fire Test Rating
A
Waterproofing Method
Structural Waterproofing
Function Configuration
Adapted to rapid shutdown, SunSpec compliant/NEC2020-690.12 compliant
