IP66
98.60%
The GoodWe EO G2 Series single-phase off-grid inverter is an ideal solution for homes in areas without grid access or those experiencing frequent power outages. It supports direct generator connection and parallel operation of up to 10 units for flexible off-grid power, while the user-friendly setup minimizes installation costs. As an efficient, flexible, and reliable off-grid solution, the EO G2 provides households with continuous energy security.
IP66 Protection: Aviation Grade Connectors
200% PV Oversizing: Lower CAPEX Higher ROI
4.3″ Touchscreen: Easy On-site Control
Multi-Scenario Support: Grid, PV, ESS, Generator
IP66
98.60%
Maximize energy harvest with up to 200% DC oversizing and scale your system with 10 units parallel operation. It also allows 3 single-phase units to form a three-phase system, adapting to diverse off-grid needs
21A PV Input per String: Compatible with 99% PV modules
98.6% Max Efficiency: Higher Lifetime Revenue
With IP66 protection, the EO G2 is built to withstand harsh outdoor conditions, while Type III AC/DC surge protection safeguards against voltage spikes, ensuring long-term reliability for off-grid applications.
Built-in GFCI: Enhanced Electrical Safety
-20°C to 55°C Operation: Harsh Environment Ready
GW6K-EO-G20
40~60
130 / 130
Max. MPPT Current (A)
21 / 21
Max. Apparent Power from Grid (kVA)
8
220 / 230, L / N / PE
GW5K-EO-G20
40~60
120 / 120
21 / 21
8
GW3.6K-EO-G20
40~60
90 / 90
21
8
GW3K-EO-G20
40~60
70 / 70
21
8
