Quiet operation
98.70%
GoodWe's SDT G3 Series inverter is designed for three-phase residential and commercial applications. With a capacity range of 25kW to 40kW, it offers flexible options to meet various power requirements. Additionally, its high efficiency, smart functions and user-friendly design ensure increased ROI while delivering ultimate convenience.
Max. 21A input current per string
Mixed parallel connection with GoodWe SDT G3 series
In-built Type II SPD on AC & DC sides
Lightweight design for easy installation
Quiet operation
98.70%
The SDT G3 Series inverter supports up to 180% PV input oversizing, maximizing energy yields for enhanced ROI. With a maximum input current of 21A per string, it accommodates high-current PV modules for greater compatibility. Additionally, its wide MPPT operating voltage range ensures optimal energy production even under low solar radiation conditions.
Up to 180% PV input oversizing
Wide MPPT voltage range
Type II surge protection on both DC and AC sides is integrated to protect the inverter from lightning, providing upgraded safety and reliability for the PV system. With optional AI-driven Arc Fault Circuit Interrupter (AFCI), the inverter is able to detect arc fault failure, sending alarms through monitoring systems and breaking the circuit simultaneously.
AI-driven AFCI
GW40K-SDT-P30
Max. Input Voltage (V):
40
4/2
Max. Efficiency :
98.6%
Nominal Output Voltage (V) :
220/380, 230/400, 240/415, 3L/N/PE or 3L/PE
GW40K-SDT-C30
42/42/32
3/2
Max. Efficiency :
98.6%
GW36K-SDT-C30
42/42/32
3/2
Max. Efficiency :
98.6%
GW33K-SDT-C30
42/42/32
3/2
Max. Efficiency :
98.6%
GW30K-SDT-30
40
3/2
Max. Efficiency :
98.7%
GW25K-SDT-30
40
3/2
Max. Efficiency :
98.7%
