IP66
<50dB
The SDT G3 Series inverter, available in 30–50 kW capacities, delivers exceptional performance with ultra-low noise operation below 50 dB, making it ideal for a wide range of commercial and industrial (C&I) applications, especially noise-sensitive environments such as schools and hospitals.
Max. 21A per string & 180% PV oversizing
AI-driven AFCI 3.0 for safety
Operate quietly at under 50dB
Compact design for easy installation
IP66
<50dB
With optional AFCI, the inverter detects arc fault failures, sends alarms through monitoring systems, and breaks the circuit. Type II Surge Protection Device (SPD) on both sides guards against lightning and other hazards.
Type II SPD on both AC and DC sides
The SDT G3 inverter is engineered for maximum energy yield, featuring 4 MPPTs, up to 98.7% efficiency, and 21A input current per string. With support for 180% PV oversizing, it captures more solar energy throughout the day for optimal system performance.
21A
Max. 21A input current per string
180%
PV input oversizing
98.7%
Max. Efficiency
GW30K-SDT-C30
Max. Input Voltage (V)
42 / 32
2 / 2
Max. Efficiency
98.6%
GW30K-SDT-30
40 / 40 / 40
3 / 2
Max. Efficiency
98.7%
GW33K-SDT-C30
42 / 42 / 32
3 / 2
Max. Efficiency
98.6%
GW36K-SDT-C30
42 / 42 / 32
3 / 2
Max. Efficiency
98.6%
GW40K-SDT-C30
42 / 42 / 32
3 / 2
Max. Efficiency
98.6%
GW40K-SDT-P30
40
4 / 2
Max. Efficiency
98.6%
GW50K-SDT-C30
40
4/2
Max. Efficiency
98.7%
